MF 135 Fuel leaks out the cap
Jeff
07-05-2004 06:02:11
I have a MF 135 Perkins diesel if I fill the gas tank up over half full the gas will leak out of the gas cap like the tank is being pressurized. I have replaced the gas cap and it is vented. Any suggestions on what is going on.
downsouth
07-06-2004 13:03:52
 Re: MF 135 Fuel leaks out the cap in reply to Jeff, 07-05-2004 06:02:11
is your tractor upside down ?
Jeff
07-06-2004 15:07:10
 Re: Re: MF 135 Fuel leaks out the cap in reply to downsouth, 07-06-2004 13:03:52
That might be why the bushhog doesn't cut good
mowr
07-06-2004 05:49:52
Are you sure the fuel isn't simply sloshing out due to a cap (perhaps not the factory cap) with a seal that does not fit snugly to the tank? Or perhaps the sealing surface on the tank opening is bent or cracked?
