MF 50 Clutch
D.Hall
07-03-2004 23:28:15
I have a 1962 MF 50. It has a new clutch and pressure plate. I am having trouble with the clutch not releasing all the way. It will stop the tractor but will hold enough to make it hard to get out of gear. All the adjustments seem to be ok (I know they can be some what touchy). The PTO releases ok. There is a small amount of oil leaking in from the tramsmission, I have replaced this seal 2 times but they do not seem to last long. The problem seems to start when the seal starts leaking. Could the oil be my only problem or should I look somewere else also. Thanks for any help.
sibby(Aus)
07-04-2004 04:24:36
 Re: MF 50 Clutch in reply to D.Hall, 07-03-2004 23:28:15
Is the tranny oil sticking up your clutch plate?
