drawbar
steve t
07-02-2004 12:49:44
I'm new to the tractor thing. I want to tow a trailer with a ball hitch. When I use a draw bar on the 3 point hitch, do I need two of those brackets to keep the bar from spinning, or will one do?
Arthur from Tassy
07-05-2004 02:29:13
 Re: drawbar in reply to steve t, 07-02-2004 12:49:44
Hi Steve t
One of those bracket's should do for pulling a light weight trailer. But! do not attempt to pull anything with the drawbar at or above the height of the centre line of the back axle as the tractor will rear and topple backwards if the load increases suddenly. using the stays designed for use with that style of drawbar up to the long pin under the top link hitch point is a good precaution and then you don't have to rely on the position control which could get misplaced by a bump etc, leave that lever in the down position.
Cheers Arthur from Tassy
Cosmo
07-02-2004 18:07:57
I only use one. It will hold anything my tractor will pull. (MF35)
