MF 40 Won't turn over
John
07-01-2004 12:52:12
I have a gas MF 40 that won't turn over. Battery is good. Current indicator shows current when ignition switched turned on. There is no clicking sound at the starter motor. After repeated attempts(15 - 20 times) engine finally turned over, started easily and ran fine for an hour til I turned it off. Then wouldn't turn over again after repeated attempts. Where do I start? Solenoid?, Ignition switch?, starter motor? Any help is appreciated. Thanks
tim
07-04-2004 06:24:45
 Re: MF 40 Won't turn over in reply to John, 07-01-2004 12:52:12
hapend with mine found bad cable end at starter have to remove carb to check gl tim
Stan(PA)
07-01-2004 14:46:19
My guess would be bad solenoid. Make sure tractor is in neutral, and jump across the solenoid. If starter spins, I'd say you found the problem.
sibby(Aus)
07-04-2004 20:19:57
 Re: Re: MF 40 Won't turn over in reply to Stan(PA), 07-01-2004 14:46:19
John, Check your safety start switch.
sibby(Aus)
07-05-2004 05:54:42
 Re: Re: Re: MF 40 Won't turn over in reply to sibby(Aus), 07-04-2004 20:19:57
John, Try hitting your starter motor just under the solenoid with a 3 to 5 pound piece of wood a coupla times, in case you have sticky brushes. Regards, sibby.
