Massey Ferguson 245
Tim Rose
06-29-2004 11:29:35
need a little help with front end loader purchaced a allied to go on a 245 massey but it works to slow is the pump for the 3pt hitch big enough to run the front in loader or do i need to go with a aux pump the unit seems tobe plenty strong
Thanks in advance
Tim Rose
GaryF
06-29-2004 19:04:53
 Re: Massey Ferguson 245 in reply to Tim Rose, 06-29-2004 11:29:35
It is OK to use the internal pump to run your loader. You will not be able to operate the 3 point hitch while you are using the loader. The front mounted pump is the best way to go if you plan to do a lot of loader work however it will cost a few bucks. Why not use it the way it is. If you are satisfied do nothing. If not buy the front pump and hardware. You may also have to cut a hole in your tin.
Gary
Tim Rose
06-30-2004 13:15:06
 Re: Re: Massey Ferguson 245 in reply to GaryF, 06-29-2004 19:04:53
when a said it was slow a mean about a min. or more to go the full range of the cylinders i wonder if the porting might be wrong on the valve block or is this normal the cylinders are maybe two inch maybe 2 1/2
