Perkins 540
Rob
06-28-2004 20:00:56
Does anyone out there know if it is possible to put 640 pistons in a 540? I was thinking about trying it.
Thanks
Rob
Tommy D6-8U
07-03-2004 06:33:07
 Re: Perkins 540 in reply to Rob, 06-28-2004 20:00:56
Rob,
Yeah I mean't to say 540! (duh) The parent bore on the 540 is 4.456 so its still a little small. Just curious, are you trying to rebuild a 540 or make a 640? I can ask around work about a block. We deal mostly with 4 and 6 cylinder engines but I will see what I can come up with.
Tommy
Tommy D6-8U
07-01-2004 18:34:17
Rob,
They would be on the tight side. The 540 is 4.25" and the 640 is 4.63" bore!
Stroke is the same (4.75")
Tommy
Rob
07-01-2004 20:54:14
 Re: Re: Perkins 540 in reply to Tommy D6-8U, 07-01-2004 18:34:17
I'm talking about running without sleeves. I might have to get larger pistons and bore it larger. Probably would need some custom head gaskets made.
Rob
Tommy D6-8U
07-02-2004 03:04:14
 Re: Re: Re: Perkins 540 in reply to Rob , 07-01-2004 20:54:14
Rob,
I'll try to remember to look today for the size of the parent bores on the 640. I work at a Perkins dealer.
Tommy
Rob
07-02-2004 17:59:02
 Re: Re: Re: Re: Perkins 540 in reply to Tommy D6-8U, 07-02-2004 03:04:14
Tommy,
Thanks for any help you can provide. I would need the parent bore of the 540 block though. Do you know where there are any 640 blocks?
Thanks
Rob
holm
07-03-2004 13:08:54
 Re: Re: Re: Re: Re: Perkins 540 in reply to Rob, 07-02-2004 17:59:02
Hi, The 540 block can be bored to except the 640 pistons. If you score a piston you will probably have to replace the block. This is done quite often for tractor pulling.
