MF 205 Industrial Question
Larry
06-25-2004 09:51:07
We bought a MF 205 Diesel Industrial recently. My question is about the PTO. This tractor doesn't have a PTO. Does anyone know if there are parts behind the PTO delete cover and all I need to get is the PTO shaft, seals etc? Some brands built in the necessary PTO parts in case the owner wanted to add it later.
Also need a good front grill cover or a good close up picture an original grill if anyone out there has one. Thanks.
Larry
islacool
09-23-2006 14:37:04
 Re: MF 205 Industrial Question in reply to Larry, 06-25-2004 09:51:07
Hello,
i search a document of mf 205x
Can you me helpen,please
ben (Belgium)
rod
06-27-2004 05:09:21
send me your email and I will scan and send you a pic from the original owners manual of the grill.
regards
rod
I also have the parts book, and shop manual
GaryF
06-25-2004 16:54:51
Larry all parts you need can be obtained from a "donor MF35" which ones depends on if your 205 has 3 point hitch or not. Your pto will turn the opposite way when the trans is shifted into reverse. So far as the grill goes I need one myself and have seen others missing it. Maybe they are a collectors item!!!
