Don't see many MH 30s for sale - How come?
LeRoy
06-24-2004 18:36:10
I'm just noticing that there aren't many MH 30s for sale. Was wondering if anyone else noticed that? Parts shouldn't be an issue with these should they?
LeRoy
Alberta Mike
06-25-2004 13:41:16
 Re: Don't see many MH 30s for sale - How come? in reply to LeRoy, 06-24-2004 18:36:10
Engine parts are very available since MH used Continental flathead 4-cylinder engines in those model 30's. Most were the 140 cubic inch size but I think some were 162's. Same engine other than the cylinder bores and piston/rings. They were used on a ton of agricultural and industrial stuff too (including untold numbers on Lincoln welders). The transmission/differential unit was the same as on the earlier 101/102 Juniors and Seniors. Sheet metal was different than those models though (fenders probably the same). You see a number of the wide fronts up here for sale now and then, certainly not thought of as a rare tractor. A lot of guys still use them a bit for small hay operations, etc. They were replaced by the model 33 (overhead valve engines) around 1050 or thereabouts.
LeRoy
06-26-2004 13:29:24
 Re: Re: Don't see many MH 30s for sale - How come? in reply to Alberta Mike, 06-25-2004 13:41:16
Was just in a conversation with someone about a 44-6 and the 226 continental it used. Didn't realize that these engine were in Willys and Kaisers also.
LeRoy
gerald
06-25-2004 16:48:38
gee mike, i have a '48 model 30 gr and i haven't seen any more like mine here in central tx. maybe you have some contacts for parts and implements like say maybe an auger for post holes or maybe a radiator(mines leaking). i also need to fix my lift gear(mine doesn't work). i'm in the process of rebuilding and have just finished the engine with the help of a few suppliers i've found for the continential f162 that is in my mh-30. had a hard time finding these suppliers but finally did. i used my mh-30 for the first year or so just mowing grass around here then the waterpump went out, checked with the local tractor supplier and he wanted $360 for a rebuilt one so i pulled the tarp over the tractor and didn't bother with it for a year or two but i've reciently decided to rebuiled and lo a behold i found a new pump for $140. well send some tips if you can sounds like you know a few. thanks gerald
junction28
07-26-2005 11:52:17
 Re: Re: Re: Don't see many MH 30s for sale - How c in reply to gerald , 06-25-2004 16:48:38
I"m having a hard time finding any implements to fit my MH30. The PTO shaft is too high to fit anything I own.
LeRoy
06-26-2004 13:27:00
Could you mention those suppliers in case I find a MH 30 around PA.
LeRoy
Tom
06-26-2004 18:03:11
 Re: Re: Re: Re: Don't see many MH 30s for sale - H in reply to LeRoy, 06-26-2004 13:27:00
I'm near Albany NY. I've got a couple of MH 30 tractors I'd sell.
LeRoy
06-26-2004 18:14:47
 Re: Re: Re: Re: Re: Don't see many MH 30s for sale in reply to Tom, 06-26-2004 18:03:11
Tom,
Like to see what ya got if have pics you can email. Looking to buy in the Spring already blew the tractor budget on a Ferguson 40 this year and restoring a MH Pacer and AC B Cane Special. Not sure when you wanted to sell.
LeRoy
Alberta Mike - make that
06-25-2004 13:43:04
Not too many tractors around in 1050, well maybe some John Deeres but no Masseys.
msb
06-24-2004 19:41:11
Here's one.listed in today's "Indiana Auto & RV" ad paper:1950 Massey Harris 30-Runs good,good sheet metal,12 volt,good tires,decent paint.$1650 OBO,Daleville,In,(765)354-4123 See the pic I suppose at www.autorv.com -----(in "B" magazine)
LeRoy
06-26-2004 13:30:42
 Re: Re: Don't see many MH 30s for sale - How come? in reply to msb, 06-24-2004 19:41:11
Couldn't find the Pic for this tractor, did you find it?
LeRoy
msb
06-26-2004 15:55:54
 Re: Re: Re: Don't see many MH 30s for sale - How c in reply to LeRoy, 06-26-2004 13:30:42
Not sure picture on website.I have a copy of the ad paper here.Tractor looks to be in decent shape as far as I can tell.Headlights are mounted up on grille sides.Daleville is only about 35 miles from me.I guess I could run up and take a look for you if you are interested in it.
LeRoy
06-26-2004 18:08:47
 Re: Re: Re: Re: Don't see many MH 30s for sale - H in reply to msb, 06-26-2004 15:55:54
Its too far for me. I was interested in looking at a pic to get an idea of what it was like for that price. Just bought a Ferguson 40 and restoring a MH Pacer so money funneling there at the moment. Better chance for the spring.
Thanks for the offer though.
LeRoy
