MF 245 bypass top arm draft control?????
Louie
06-23-2004 14:14:07
I have a MF 245 and bush hog 30 acres of old pasture. When ever I hit any rough turf the top arm of the 3 point hitch pushes in on the draft control located right beneath the back of the seat.
It then temporarily lifts the implement. I know what this is for when plowing etc.. but when bush hogging it leaves strips of "Mohawk like cut."
I have temporarily hooked a 1/2 inch chain inplace of the top arm and this works well but would rather use the adjustable link. Is there a way for me to do this by "Turning off" the draft?
Louie
06-24-2004 06:03:29
 Re: MF 245 bypass top arm draft control????? in reply to Louie, 06-23-2004 14:14:07
Big Dean,
Draft lever is all the way up. Using the position lever to control the height. This happens with the draft lever all the way up and the control lever almost all the way down (to the height I need to cut the field.)
Thanks Big Dean and take care of the old ticker, we are in the same boat.
Big Dean
06-23-2004 15:31:02
Louie do you have the draft lever (outside lever) in the fully raised position & using the position lever (inside lever) to control the lift height this should stop that.
joss
06-27-2005 09:41:21
 Re: Re: MF 245 bypass top arm draft control????? in reply to Big Dean, 06-23-2004 15:31:02
je recherche schema electrique mf 245 i search a electric diagram for mf 245 thank
Robert Paquette
11-08-2005 04:17:59
 Re: sch�ma �lectrique in reply to joss, 06-27-2005 09:41:21
je recherche le sch�ma �lectrique du tracteur ford model 2n et 8n
