MF135 2 stage clutch
Ray,IN
06-22-2004 21:15:18
I've adjusted the 2nd stage clutch per Big Dean's website and it still will not disengage. I must stop the engine, engage the engine PTO, then restart the engine to use PTO driven implements. If I attempt to shift the PTO lever while the engine is running and the clutch pedal fullly depressed the gears clash badly. I'm stumped, what is the cause and how can I fix it?
mowr
06-23-2004 16:53:18
 Re: MF135 2 stage clutch in reply to Ray,IN, 06-22-2004 21:15:18
The most common cause is a traction drive clutch that needs replacing. The tractor must be split to replace it. Unusual but possible, I suppose, is a pto clutch disc that is rusted to the pressure plate.
Ray,IN
06-23-2004 20:46:41
 Re: Re: MF135 2 stage clutch in reply to mowr, 06-23-2004 16:53:18
mowr- I think I found the cause while looking through Big Dean's pictures website. The 2nd stage is unusually hard to push down, and his explanation makes perfect sense. He says someone replaced a part of the 2nd stage clutch with a non-matched part, which prevents the clutch from disengaging. Thanks for the reply, please look at the site and see if you concur:
