massey 44 std hard to turn over with 6 volt batt
jack shellman
06-17-2004 17:23:55
I put a 12volt on and it starts right up . could it be the starter is bad?I used a new 6 volt and it would hardly turn over.The cables were all new and so is the coil Iwould appricate any ideas.
bob
06-19-2004 17:31:56
 Re: massey 44 std hard to turn over with 6 volt in reply to jack shellman, 06-17-2004 17:23:55
Sometimes on older tractors the starter mount gets so it needs to be cleaned and sanded so the starter will make good contact with the flywheel housing.Its a good idea to wire wheel the bolts too.
marlowe
06-17-2004 19:26:57
new cables? what size? should be at least 0 or OO NOT the cheep ones for 12 volt they will not carry the amps for 6 volt
MF
06-17-2004 19:26:11
Starter 'could' be bad but probably not. I would check and clean ALL of the connections between battery and starter. Are the "new" cables big enough for 6V? If they are the wimpy 12V cables they aren't big enough.
