44 Starter Switch
ET
06-15-2004 06:49:49
I am lookig for a source for a good heavy duty starter push button switch to go on the dash of our MH44. I can get one from an auto parst store that works for a while but its not heavy enough. The cable studs on the origonal switch were 3/8" and all the replacements I have found have 5/16" studs. They just don't stand up to the amperage for very long.
jake
06-15-2004 09:02:55
 Re: 44 Starter Switch in reply to ET, 06-15-2004 06:49:49
i'd suggest you keep the low amperage switch, and instead of directly engaging the starter with it use it to actuate a relay, which then direct's the current to the starter. even a small 2$ relay can stand currents up to 30 amps.
ET
06-15-2004 09:27:37
 Re: Re: 44 Starter Switch in reply to jake, 06-15-2004 09:02:55
Jake, I have been kicking your idea around for a while myself. A farmall 300 or 400 used a 6 relay to power the starter. They were a regular change item on those tractors too.
Don
06-15-2004 07:41:06
You may just have to go with an older-style foot switch common on Farmall's, etc. They were made pretty heavy and should still be available somewhere. I have one mounted on the dash and works well. Try to have a way of QUICKLY disconnecting battery in case anything in the dash area shorts out and/or catches fire, as the fuel tank is only an inch or two away!
ET
06-15-2004 09:05:19
 Re: Re: 44 Starter Switch in reply to Don, 06-15-2004 07:41:06
Don, I thought about one of those switches but the ones I have seen are a larger diamiter than the origonal switch and I didn't realy want to cut the dash.
Tom Dold
06-15-2004 10:02:51
 Re: Re: Re: 44 Starter Switch in reply to ET, 06-15-2004 09:05:19
ET
Use a Nappa ST6. It has 3/8 NF studs.
Tom
Dold Implement Co.
Howard, SD 57349
ET
06-17-2004 06:51:06
 Re: Re: Re: Re: 44 Starter Switch in reply to Tom Dold, 06-15-2004 10:02:51
Guess what? I ordered up the st6 switch from nappa and got another one with 5/16" studs. Good try though thanks for you efforts.
