cracked sleeve
Rod
06-13-2004 08:55:49
My 150 massey ferguson diesel was gushing large amounts of coolant from the radiator overflow.I suspected a blown head gasket or cracked head. However, once i got the head off the gasket and head appears to be fine. The problem appears to be a large 2 inch crack in the #1 cylinder wall. Before i replace the sleeve, what should i look for that might have caused this problem?
sibby(Aus)
06-13-2004 15:35:43
 Re: cracked sleeve in reply to Rod, 06-13-2004 08:55:49
Rod, We dont have 150 model down under, could the engine have frooze at some time and cracked the sleeve.? Is it a dry or wet sleeve.? If it is a dry sleeve that means your engine block must be damaged where the sleeve is located, if it is a wet sleeve just replace the sleeve. Is it diesel or gas engine.? cheers, sibby.
sibby(Aus)
06-13-2004 15:37:38
 Re: Re: cracked sleeve in reply to sibby(Aus), 06-13-2004 15:35:43
Sorry Rod, i see you said Diesel, is it a 3.152 perkins?
Rod
06-13-2004 19:02:56
 Re: Re: Re: cracked sleeve in reply to sibby(Aus), 06-13-2004 15:37:38
Yes it is a perkins diesel w/wet sleeves.NO it has never frozen.
sibby(Aus)
06-13-2004 19:38:41
 Re: Re: Re: Re: cracked sleeve in reply to Rod, 06-13-2004 19:02:56
Rod, I am sure that they should have dry sleeves, i havnt seen a 3.152 with wet sleeves down under unless you have different versions over there.
