Massey 178 power steering.
Sean
06-12-2004 07:59:10
I have a 178 steering issue. the selector valve on the front of the tractor can be adjusted so that it will turn well either right/left but not both. The pins big dean mention do not have much play but the main knuckle does. What do you guys think I need to start replacing or adjusting.
thanks in advance
sibby(Aus)
06-12-2004 22:26:31
 Re: Massey 178 power steering. in reply to Sean , 06-12-2004 07:59:10
Sean, What do you call the big knuckle.? You will have excess wear and play in steering in your relay assembly, E.G. where your steering arm is connected in front of tractor behind the grille. If you have wear in the vertical shaft and or the bushes it will have the same symptoms you describe, hard one way only. Rebush and rheam and have shaft built up and machined if worn. Good Luck, sibby.
Arthur
06-19-2004 03:24:30
 Re: Re: Massey 178 power steering. in reply to sibby(Aus), 06-12-2004 22:26:31
Owyargowin Sibby
Havyar sussed out BEPCO and whatda yah think about em?
Enuff ov the ozzy inglish
I have found that buying after market parts sometimes beats the cost of labour trying to rebuild the old parts, unless for instance the bushing has gone completely and the housing has been damaged
Cheers Arthur
sibby(Aus)
06-19-2004 18:33:04
 Re: Re: Re: Massey 178 power steering. in reply to Arthur, 06-19-2004 03:24:30
Eh Arthur, Non genuine parts are not too bad, but sometimes ya get what ya pay for, ive used bepco, vapormatic and bareco parts, they do the job, never seen a shaft wear through the steel backing of that bushing before, but spose always a first time. where ya from mate.? throw nother shrimp on the barbie for ya cobber, cooee!!!
