MF 20 IND what type fluid in power steering
David Brehm
03-28-2000 10:04:08
The manual calls for M-1129A, same as trans. Would Transhydraulic or just hydraulic work. Also is this the correct service manual for this tractor. MF 20 IND TLB. What does TLB mean.
Jack in NB
03-30-2000 02:28:14
 Re: MF 20 IND what type fluid in power steering in reply to David Brehm, 03-28-2000 10:04:08
"Tractor-Loader-Backhoe" would fit for the TLB.
Just a guess; Big Dean might have official info on that point.
DeChamp
03-29-2000 18:56:45
David, I have a MF 2135 industrial/loader & my manual says to automatic trans fluid. (dextron III) But I was told to use transhydraulic fuild instead because the trans fluid turns the seals to mush. I've used it in my tractor in the dead of winter here in Michigan & the power steering worked just fine.
Jay
03-29-2000 05:16:17
David, I run Dextron III in mine. I believe tranny/hydraulic oil is more viscous and might give you hard steering during cold weather. I also remember reading a IT manual which stated automatic tranny fluid was okay. Unfortunately, I don't have answers to your other questions.
