velvet ride
06-09-2004 10:08:34
Re: MH 44 special fenders in reply to mark, 06-08-2004 21:00:35
Assuming a row crop, the bolt up replacement would be 44 Special fenders, which have the double slot lower mount, and lamp cable races. To retro any other, will require adding flat stock, welding, drilling more holes. Not a nice fit,if you are planning restoration of this classic. Though the Triple3 &4 fenders appear identical, they are NOT. The 'flat stock' fender frame sits one inch higher(T.Y., Mr.R.).This causes conflict trying to secure the OP station treaded foot platforms. Alignment of numerous bolt holes, leads to compromise original design. The rachet lock for the brake demands design update. Better to avoid the 'looks like' Triple fenders. Consider fixing your fenders, cut out rot, get some sheet metal. Take to a auto body shop, they may weld the sheet metal, grind, you do detail finish. A pair of no-rot fenders can cost a quick hundred dollars. Are yours beyond repair? Shipping is the bigger issue, on old iron parts. How much do you want to invest in leaving your present fenders, at the scrap yard?
