Massey 285 Hydraulics
Jim
06-08-2004 08:05:37
First, forgive my ignorance. I just bought a 285 and brought it home, all seemed to be working well, but now the hydraulics will not lift any weight. They will come up quick till something is hooked up, i.e. a 3pt bale spear. If I lift it then put weight one it, it will lower slowly. Also it seems to be leaking oil from the clutch release bearing fitting hole. I felt like we got a good price for the tractor and expected to do some work on it, so these are not complete suprises. I looked on this board and the overall opnion seems to be very favorable for this tractor which is what swayed my decision on the purchase. Any ideas you have would be helpful. Thanks for your time.
Big Dean
06-08-2004 08:58:25
 Re: Massey 285 Hydraulics in reply to Jim, 06-08-2004 08:05:37
The oil leak at the bellhousing is probably the transmission input shaft seals leaking If you have multipower it could take about $500 worth of parts to repair that. I am sure the hydraulic problem you are having is caused by a weak master control spring this was very common on them. If I can be of further help Email me
