drive axle
dogrex
06-07-2004 19:24:54
A Friend of mine has a 150 MF that the axle shaft or hub whatever you want to call it has chewed the bearing up.I have had dealings with old ford stuff but this is new to me,it has some sort of a planatary gear setup.What parts will he need?The end of the shaft is chewed up pretty good,any ideas?
Big Dean
06-09-2004 16:03:14
 Re: drive axle in reply to dogrex, 06-07-2004 19:24:54
The Row Crop MF150 tractors did have the rear axles with the planetary on them. The regular low profile & high clearance MF150 do not have the planetary on the rear axle. I am not sure which planetary was used on the MF150 Row Crop there was three different ones use while the 100 series tractors were in production. I have pictures all three. I you will send an email address I can send the pictures for you to look at once you figure out which one you have I can help you find parts for it.
