massey ferguson 30B pictures or info?
jim muss
06-05-2004 13:02:00
I purchased a 30B series type tractor. However, unable to find info or pictures to support the make or model any info will help there is no seryal numbers that we can find just associated part numbers. If you can help GREAT!!!
Big Dean
06-05-2004 22:46:53
 Re: massey ferguson 30B pictures or info? in reply to jim muss, 06-05-2004 13:02:00
There is a picture of a 30B here if this link works If not Email me
Tommy D6-8U
06-05-2004 15:13:08
Jim,
Tommy here from SC. I don't have any pics but you should be able to find the tractor serial number on a flat area on the upper right side of the clutch/transmission housing right behind the starter (top surface). It may be hard to see, especially if it has a loader on it. The engine number will be on a flat area on the RH side of the engine just in front of the starter at the top of the block. It could also be on the left side in a similar position right above the injection pump. I think there is also one stamped into the rear end housing on the top surface near the hydraulic lift cover. I used to work at a Massey dealer in the early eighties and this tractor was somewhat current then so it should be a mid to late eighties model? Hope this helps.
Tommy
ng
06-05-2004 20:03:34
 Re: Re: massey ferguson 30B pictures or info? in reply to Tommy D6-8U, 06-05-2004 15:13:08
Would this be an Industrial Tractor?
Tommy D6-8U
06-06-2004 08:37:12
 Re: Re: Re: massey ferguson 30B pictures or info? in reply to ng, 06-05-2004 20:03:34
NG,
Yes it is. It is about the equivalent of a 245 ag tractor but with a fixed front axle I think. It also has wet brakes (I think). I will also have a foot throttle and many times will have a forward/reverse shuttle transmission.
Tommy
