fuel tank removal
patrickvol
06-04-2004 19:28:21
if i remove the fuel tank (i think i might need to change the t-stat) will the fuel lines need to be bleed?
Tommy D6=8U
06-04-2004 20:36:42
 Re: fuel tank removal in reply to patrickvol, 06-04-2004 19:28:21
Patrick,
Usually not. Right after you take the lines loose, find something to cap them off with such as a plastic plug. When you put them back on, open the fuel valve a little to let the fuel come out, put the line on and then tighten. As long as the filter stays full, bleeding is usually not required.
Tommy
