MF35 hydraulics
Jim Orr
06-04-2004 11:32:43
I have recently bought a very tidy 1958 4 cylinder diesel MF35. The hydraulics work OK but there is a problem in that with the positioning lever set to the lowest position the lifting arms do not go down low enough to "ground" your implement e.g. transport box or buckrake - on lowest setting they are still about 4-6 inches above ground. If you switch off engine arms will eventually drop and "ground" the implement. Any ideas?
sibby(Aus)
06-04-2004 18:17:06
 Re: MF35 hydraulics in reply to Jim Orr, 06-04-2004 11:32:43
Jim, sounds like your hyd adjustments are out, drain oil to just below the bottom of your side plate on R.H. side of diff housing, the one with oil level dipstick in it, remove plate and with both position control and draft levers in fully lowered positions adjust the nut that holds your control valve positioning lever until it drops the linkage arms fully down. Do you have a manual for it.? cheers sibby.
