ATT PONY OWNERS
DAVE H
06-03-2004 23:03:12
I have a 1948 pony. the fuel bowl is right by the carb and the air intake tube is in the way. ive seen some fuel bowls under gas tank but the manual says it goes by the carb. does anyone now for sure??
ray-s
06-06-2004 21:35:44
 Re: ATT PONY OWNERS in reply to DAVE H, 06-03-2004 23:03:12
third party image
Our pony will be a working tractor, so to make it easier to shut the fuel off we made a bracket and put the sediment bowl in the open. Also made the brackets for headlights. Ray-s
Keith(Texas)
06-04-2004 08:58:07
Dave, all my Pony manuals indicate that the fuel bowl was next to the carburetor on the 1947 & 1948 pony's with a fuel shut off valve just to the left of the fuel bowl. In 1949 the fuel bowls were moved to the gas tank beginning serial# PGA 3117 and up. Hope this helps, Keith
dave h
06-04-2004 12:33:11
 Re: Re: ATT PONY OWNERS in reply to Keith(Texas), 06-04-2004 08:58:07
keith were does the air breather go on the outside off all that
Keith(Texas)
06-04-2004 16:57:05
 Re: Re: Re: ATT PONY OWNERS in reply to dave h, 06-04-2004 12:33:11
Dave, the fuel path goes from a Half Union coupling (GA 3093)in Bottom of Fuel Tank, thru a fuel line (850-025-M11) 1/4in. tubing , x 8-3/4in. long, behind the air breather pipe to a Shut-off Valve (850-323-M1), then thru a Fuel Line Extension (850-601-M11), with fittings 1/4in. Tubing 2in.long, then through a Connector fitting (850-649-M1) into the Gas Strainer (850-042-M1), Filt-O-Ret 65. I have seen this configuration on a 1948 pony with the Fuel strainer screwed into the back port of the carburetor. This info is probably a lot more than you wanted but I hope it helps.
dave
06-07-2004 21:55:39
 Re: Re: Re: Re: ATT PONY OWNERS in reply to Keith(Texas), 06-04-2004 16:57:05
thanks for the info keith.i guess the air cleaner tube goes on the outside of all this dave
Stan(PA)
06-04-2004 05:57:15
Don't know for sure how it should be, but my '51 has it under the tank.
