Tommy D6-8U
William Bos
06-03-2004 19:45:27
Hi Tommy,
Just bought a A3.152 (indirect injecte3d, rear rope seal)Perkins for ( and from) a MF 35. It needs and injector pump, and it came with out the pump. are they still available through Perkins. Could you find out for me please? I also need fuel lines, and oil lines and a few other parts. Also, will fuel, and oil lines from a Direct injected model work on the indirect injected model?
Thanks,
Will
If you need anymore info, as soon as the engine arrives, I will gladly give you the serial number.
Thanks
Will
Tommy D6-8U
06-04-2004 06:09:52
 Re: Tommy D6-8U in reply to William Bos, 06-03-2004 19:45:27
Will,
Most everything should be available for your engine but the injection equipment might be best found used. The cylinder head and configuration on the injectors is a little different between direct/indirect injection. If you can get me the numbers off it I'll see what I can find out. E-mail me directly if you want; Its "unhidden" on this post.
Tommy
