MH 44 Spec/MF 85 Diesel motors
MoJohn
06-03-2004 19:13:57
are there a difference between the MH 44 Special HD277 diesel and the MF85 HD277 diesel.Thanks
John
velvet ride
06-04-2004 09:07:22
 Re: MH 44 Spec/MF 85 Diesel motors in reply to MoJohn, 06-03-2004 19:13:57
There were no known 44 D Specials built with 277
diesels, only 444D's. The Special Diesels were HD
260's, with marginal changes from the 44D engine.
Given choice, one would keep the diesel in the
Special, being a more durable tractor than the
forgotten 85, Since the 85 has no frame, the front axle is attached to the engine. The 277
in the 85 has a different pan than the 444's
277.
Bob
06-04-2004 17:00:50
 Re: Re: MH 44 Spec/MF 85 Diesel motors in reply to velvet ride, 06-04-2004 09:07:22
Are the engines the same other than the base?
velvet ride
06-04-2004 18:26:01
 Re: Re: Re: MH 44 Spec/MF 85 Diesel motors in reply to Bob, 06-04-2004 17:00:50
You now approach S/N breaks, as Continental was
modifying cams, timing. Short answer: having two
complete engines, should produce one that runs
decent, provided that the other is not blown.
