normal operating temp?
patrickvol
06-03-2004 13:57:04
i have a 72 model 20 ind and was wonder what the temp shoud be after it warms up(befor any work is done). my temp gauge did not work but i have replaced and it wont move just seating there ideling. i jsut tested the temp gauge and it works. could the thermastat be missing, (the manual is ordered) where is the thermastat at and what has to be done to get to it?
thanks
Tommy D6-8U
06-03-2004 17:42:32
 Re: normal operating temp? in reply to patrickvol, 06-03-2004 13:57:04
Patrick,
If you have the 3 cylinder diesel (3.152 Perkins) which I'm sure you do, the operating temp or thermostat should be in the 165 to 180 range. You probably need to replace the thermostat. There is a common misconception that cooler is better but it is not. The engine (or most any engine) is designed to run at a certain temp. On these particular engines, temperature is critical to maintain uniform heat in the cylinder head and block. If it has hot or cool spots, they are prone to blowing head gaskets between cylinders. The thermostat is located in a housing on the top front of the cylinder head just below where the upper water hose connects to the engine. Make sure you have a mix of antifreeze and water not to exceed a 50/50 mixture. Too much antifreeze can cause piston scuffing and isolated hotspots in the engine as well. I hope this helps; good luck!
Tommy
patrickvol
06-03-2004 18:27:58
 Re: Re: normal operating temp? in reply to Tommy D6-8U, 06-03-2004 17:42:32
wow sounds like the fuel tank needs to come off then. yes it is the 3cylinder diesel. so the tractor should have come up to temp ideling? right. i guessing a MF dearler is the only place to get a new thermostate and gasket?
thanks patrick
go vols
Tommy D6-8U
06-03-2004 18:37:26
 Re: Re: Re: normal operating temp? in reply to patrickvol , 06-03-2004 18:27:58
Patrick,
Yes the fuel tank has to come off or be raised enough in the front to get the housing off. I have done it that way on service calls but be careful with the fuel supply line at the bottom of the tank and the fuel return line in the rear of the tank. ITs best to unhook them if you don't have a good way to lift the tank off or no help.
If you can get the thermostat out take it with you to a NAPA store and they probably have a listing for it; its not really special.
Tommy
patrickvol
06-03-2004 14:36:53
well after some more testing today looks like it goes up to about 120 degress at 2000rpm not working. does this sound about right? what temp thermastat do they put in one? i watch with the rad cap open and hardly seen water moveing. the thermastat never opened that i saw, but the only thing i have work on is old truck so what do i know. thank for any help
patrick
go vols
patrickvol
06-03-2004 13:58:30
sorry its a diesel
thanks
