oil pressuer gauge
patrickvol
06-02-2004 14:15:08
well i got my first tractor and the oil pressuer gauge dont work. will any gauge work on it? i have put many of the little gauges on old trucks and was hopeing that something like that would work. i am wanting to replace the line all the way to the block dont know if it will screw in. thanks for any help
patrickvol
RandyN
06-02-2004 19:12:50
 Re: oil pressuer gauge in reply to patrickvol, 06-02-2004 14:15:08
Correct mechanical oil pressure gauges (for our beloved tractors) are readily available from this website, other websites, or at most farm and home type stores like Tractor Supply, Orscheln, etc.
RandyN
Alberta Mike
06-02-2004 14:27:31
If you are talking old trucks in your experience, you are probably dealing with mechanical oil-pressure gauges (where there is a very small diameter oil line between the block and the gauge). Any of those would work except newer mechanical gauges read such high pressures and if it's an old tractor you're dealing with, the needle will barely get off the line if it runs 12 pounds of pressure on a 100 pound gauge. If it is electrical, there is a little sending unit at the block (threads in) with a wire attatched to it which goes to the electric gauge. Most of that stuff now would be 12 volt. In either one, the block thread is probably a 1/8" pipe size thread.
patrickvol
06-02-2004 14:32:07
 Re: Re: oil pressuer gauge in reply to Alberta Mike, 06-02-2004 14:27:31
i am working on a mf-20. yes i am talking about mechanical and the ones like they sell at the auto parts place wont read right?
Alberta Mike
06-02-2004 14:42:21
 Re: Re: Re: oil pressuer gauge in reply to patrickvol, 06-02-2004 14:32:07
It will read correctly, it's just that most newere gauges have a very high maximum reading on the dial, say 100 pounds at the end of the scale. If your tractor is only putting out 15 pounds of pressure, the needle barely moves from the zero point at 15 pounds. If you can get a gauge (low pressure range like the older stuff was), then the top end of the gauge might be 30 pounds so a 15 pound reading will have the needle right in the middle of the scale. Just my preference, the newer types are fine.
patrickvol
06-02-2004 14:45:13
 Re: Re: Re: Re: oil pressuer gauge in reply to Alberta Mike, 06-02-2004 14:42:21
oh ok i have not looked at stuff like that in years. thanks
