To 35 Stuck Clutch
Dennis Cook
06-01-2004 19:01:55
I recently purchased a to35 . The clutch will not release! Any sugestions ? Also is there a differance between a To35 & MF35 ?
sibby(Aus)
06-03-2004 00:30:13
 Re: To 35 Stuck Clutch in reply to Dennis Cook, 06-01-2004 19:01:55
Dennis, Not sure on to35, we only have fe35 and mf35 down under. Try starting your engine and let it warm up good, get some heat into your clutch and flywheel, do your brakes work good enough to go for a run with your foot down on the clutch, alter your engine revs and keep applying your brakes, jump on left brake then right brake and so on, hopefully this wiil release it, i have done this many times with no problems. P.S., get ready to switch off engine if you need to stop. good luck , bye for now.
