trading tractors
rob
05-31-2004 05:40:03
I am considering trading to a MF 1135, is this a good reliable tractor? I have never owned a massey but it appears to be a good deal, one problem the dealer says "the multi power has not worked in low for years" is this a problem and what is the multi power anyway? Is this something to shy away from? I am looking for something big enough for row crops but small enough for a hay operation, will this be a good fit? Any input? Thanks.
bstrucker
05-31-2004 13:47:29
 Re: trading tractors in reply to rob, 05-31-2004 05:40:03
I'd want to find out more about the multi-power not working.That gives you a lower gear with the flip of that little lever.Say that your plowing,and you hit a spot where you need a little extra power,you just flip that lever and you get a slightly lower gear.It's the same as a TA.We used an 1130 for baling for years and it worked great.
