MF135 Quadrant controls behaving strangely
Peter
05-30-2004 12:50:16
I just finished installing a bracket to hold a spooling valve, using the bolts that hold the quadrant lever assembly in place.
This led to disturbling the position of the levers while I had the retaing bolts out.
Now the controls are behaving strangely. The position control seems to have no effect, and only the draft control raises and lowers the arms, but the system starts to strain if I keep the arms all the way up. It almost seems as if it is in constant pumping mode. If I keep the draft control half way down or lower, everything is fine and the arms are down.
Have I mis-aligned the levers? How can I fix this?
Much thanks for any help.
Peter in Pakenham
Louie
01-06-2005 10:51:39
 Re: MF135 Quadrant controls behaving strangely in reply to Peter, 05-30-2004 12:50:16
Peter,
I just did the same thing and did a search and found your email, Big Dean mailed me the same info. From one who needed direction to another was there much to this??
Big Dean
05-30-2004 19:56:35
Peter the Position control has a piece of linkage that when you move the position lever to far it will jump out of place it will happen almost every time you do that. To get it back where it belongs you will have to remove the liftcover. I have a picture showing this & how to get it back in place If you will email me an email address I can send it to you
