Massey Steering Wheel Identification -- Maybe MF65
Jeff
05-30-2004 12:15:09
I have a large quantity of new steering wheels that I think are for a MF65 ( the older style, non-dished ). To encourage some participation, the first person to respond with the correct answer will get one steering wheel for FREE!. The dimensions are OD 17 5/8 in., shaft size 3/4 in., keyway is 1/4 in. I will post a picture under the "Help Identify" section.
THANKS!
Thomas
05-30-2004 14:57:28
 Re: Massey Steering Wheel Identification -- Maybe in reply to Jeff, 05-30-2004 12:15:09
Assuming the bore to be tapered, I think it is an MF 899623M1 wheel which fits the TE/O 20 Range, and early versions of 35, 65 and 135. They are not an exact match to the original, but I know that they are imported here to UK from the US by my usual source. See picture on www.vapormatic.com under VPJ5000, looks like yours. If it's not a tapered bore then I'm wrong.
Jeff
05-30-2004 16:26:55
 Re: Re: Massey Steering Wheel Identification -- Ma in reply to Thomas, 05-30-2004 14:57:28
The ones I have appear to be straight bored. How much taper would they have?
DP
05-31-2004 15:05:09
 Re: Re: Re: Massey Steering Wheel Identification - in reply to Jeff, 05-30-2004 16:26:55
Hi from South Wales,
The taper in the bore would be very visible with 2 keyways. The alternative is the parallel multispline hub fitted to 165 upwards and later tractors.
Cheers.
C. T. in Oklahoma
05-30-2004 12:36:02
Jeff,
Looks like they will fit the following:
TE20, TEA20, TO20, TO30, TO35, MF35, MF135, MF50, MF65, F40, MF85, Plus industrial models:
203, 205, 2135. C. T.
Jeff
05-30-2004 12:42:54
 Re: Re: Massey Steering Wheel Identification -- Ma in reply to C. T. in Oklahoma, 05-30-2004 12:36:02
I have a MF85 and it does not fit it. Can you email me where you obtained this information? We can discuss your steering wheel then. THanks, Jeff
