Hi All, A fun evening with some satisfaction but no start yet. Here�s an update on progress. Thanks again for all your suggestions. I�ve got myself in a bit of a bind for time this week and I don�t think I will be out to the 35 for the rest of the week. I have to go out of town on business on Saturday for 10 days and have my hands full until then. I�ve cleaned and checked that all (I think) connections are tight. I replaced the negative terminal that I was unable to tighten further. I seem to have a problem with the positive lead. The insulation was damaged at some point (I�ve owned this MF 35 since 2001 and the damage was done before my time) about 16� from the positive battery post and the area was covered over with PVC tape. The tape has come loose and I can see damage and corrosion of the conductor. No sign of burning or arcing to the nearby steel (rubbing / vibration against the steel probably caused the damage in the first place), but no way for me to see if the corrosion has spread significantly into the lead without destroying it. (Your�s might be the one Mark) I will change this lead. Ben UK: I had no luck with turning the key more slowly. Thanks for the suggestion. Sometimes we get lucky and sometimes not. Sibby: No luck with a piece of wood and a rubber mallet on the started near the base of the solenoid. If changing the lead doesn�t solve the problem I will revisit this and replacing the solenoid. Txblu: Thanks for your explanation of the clicking. Makes sense to me. I believe I have all the connection tight now. Obviously if the lead is not good enough to allow sufficient current past the damage the voltage will not be maintained to the solenoid. Mark: I have yet to try directly jumpering to the starter. (on the list to try if replacing the lead doesn�t solve the problem). I may try this before I change the lead, but I haven�t as yet. Swede: Cracked Bakkelite (Bakalite is the English term for this type of plastic) is also a possibility. At the moment I can�t see any cracks but the light in the barn wasn�t all that good this evening. Thanks again to all and I will post how things turn out.
Glen 130
