SOS mf65 not running right
tractor dan
05-29-2004 16:34:01
My MF 65 was running a little rough the other day so I put on a new distrib cap, rotor and plugs. The engine starts and idles OK. When a load is put on the engine starts to backfire and will not pull a load without lots of loud backfiring and missing. I have advanced and retarded the timing and it doesn't help. I have changed out the dist cap, rotor,plugs, gapped the points and filed them and it doesn't help. My buddy thinks the coil or condensor might be "weak". When the dist cap is off and the engine is turned over the spark across the points is pretty puny. The governor is working OK. Help. All ideas appreciated.
squints2see
06-30-2004 03:51:24
 Re: SOS mf65 not running right in reply to tractor dan, 05-29-2004 16:34:01
You might try cutting a little off the ends of the coil wire and putting new ends on. Ours had a weak spark and it fixed it.
bstrucker
05-31-2004 14:00:13
Check the tower on your coil for a crack.You said you replaced the cap,I'm assuming with a new one,A crack in the cap would also cause your symptoms
Big Dean
05-29-2004 23:32:39
The firing order for the G176 Continental engine is 1-3-4-2 the distributor shaft rotation is counterclockwise. If you have it wire clockwise then you have 3 & 4 plugs firing a half a round off. it is very easy to do this & the tractor will run pretty well till you put a load on the engine
tractor dan
05-30-2004 03:41:47
 Re: Re: SOS mf65 not running right in reply to Big Dean, 05-29-2004 23:32:39
Thanks Big Dean and welcome back - I hoped you would be there to help me with this!!!
