firing order continental 176
tractor dan
05-28-2004 17:12:45
I was replacing my distributor cap on my G176 continental (MF65) and I looked down and two of the distributor wires were off. What is the firing order of this engine?
George G
05-29-2004 16:37:36
 Re: firing order continental 176 in reply to tractor dan, 05-28-2004 17:12:45
On any 4-cyl. engine, they use one of only two different firing orders. One is 1243,the other is 1342. Bring the number one cylinder up to TDC (Top Dead Center). Check the rotor, the terminal the rotor is pointing to, is the number one terminal. Now put your thumb over the number two cylinders sparkplug hole. Now bump the ignition over, if you get compresson under your thumb. Then the firing order is 1243. If you hear air blast out the number three cylinder before you get compresson under your thumb. Then the firing order is 1342. Hope this helps.
