FERGUSON PLOW 14-AO-28
SCOTT PHOENIX
05-26-2004 19:58:42
I JUST BOUGHT A FERGUSON PLOW. I'M MISSING ONE CULTER AND THE TAIL WHEEL. I WAS WONDERING WERE I MIGHT BE ABLE TO GET SOME PARTS. ALSO WHAT WAS THE ORIGINAL COLOR OF THE PLOW? I'VE SEEN THEM IN GRAY AND RED WITH THE MULBOARDS BEING WHITE.
Tom
05-27-2004 12:38:27
 Re: FERGUSON PLOW 14-AO-28 in reply to SCOTT PHOENIX, 05-26-2004 19:58:42
Scott
How much of the furrow wheel are you missing? I have acomplete furrow wheel and bracket for an AO
series plow. It is new complete and never been installed. The color was ferguson grey.
Tom Dold
Dold Implement Co.
Howard, SD 57349
605-7722-4541
[email protected]
SCOTT PHOENIX
05-27-2004 18:51:59
 Re: Re: FERGUSON PLOW 14-AO-28 in reply to Tom , 05-27-2004 12:38:27
TOM, THANKS FOR YOU'R REPLY. THE BRACKET IS THERE,BUT THE WHEEL IS MISSING. I'M NOT TO SURE WHAT ELSE IS MISSING. I JUST GOT A BOOK AND NOTICED THAT THERE WAS A WHEEL THAT WAS THERE. WOULD YOU LIKE TO SELL THE FURROW WHEEL? DO YOU KNOW WHERE I COULD GET ANY OTHER PATS FOR THE PLOW? THANKS AGAIN FOR YOUR REPLY SCOTT PHOENIX
Tom
05-28-2004 10:55:44
 Re: Re: Re: FERGUSON PLOW 14-AO-28 in reply to SCOTT PHOENIX, 05-27-2004 18:51:59
Steve
I do have a wheel only also. It is the same as only it is the style as the one on my complete assy. There were two different styles. One that clamps on the axle with two cast iron clamps that fit over the hub on the wheel, and the other that style uses a bolt that goes through the hub of the wheel. I have the clamp on style. I also have the scraper for the wheel. The axle for the clamp style has 2 holes in the casting. One comming in at an angle from the rear to hold the scraper the other running verticle to accomadate a bolt for the clamps to hold the wheel on the axle. The other axle has only the hole to attach the scraper.
Tom
[email protected]
605-772-4541
