magneto problems!!!!!!
shannon
05-26-2004 15:59:33
looking for info how to get the spark in one. Can it be possible to use an o meter to test the mag?????
Allan C
05-29-2004 21:09:30
 Re: magneto problems!!!!!! in reply to shannon, 05-26-2004 15:59:33
Mag problems can be fun. First check the points and condenser. Make sure that nothing is grounding on the movable point side, Settings are correct, and the condenser and all connections are good. If you have to go deeper you need to have means of checking the coil (an ohm meter will tell you if it's open or shorted but it may have an internal short not detectable by a meter). Then there's the timing, and the impulse starter etc etc.
