glow plugs (need a resistor)
Tom Small
05-26-2004 09:40:48
I have a TO35 (23c) standard diesel; I bought 4 Lucas glow plugs #829162M1 and I cannot find a resistor for them. They are 1.7 volts each. Napa and Radio Shack can't help me, anyone have any ideas? Thanks, Tom..... ..... .
TO35
05-26-2004 16:18:56
 Re: glow plugs (need a resistor) in reply to Tom Small, 05-26-2004 09:40:48
Tom, if your handy at doing a little wiring you can add a clum relay(6.2&6.5 gm diesels use them) all you need is a wire to each plug and a selnoid turn on wire....only draw back is the clum relay(built in resitor and auto timer) is about 60 bux.
A cheaper soultion would be to wire up a bosch relay and a old style chrysler ing. resistor only problem no timer( but you could wire it to switch on with key then count to 6 then go to start breaking the connection thru the relay)...
maybe this will give you some ideas...
best wishes
TO
