CLUTCH ON MF35
RICK ADAMS
05-25-2004 10:59:56
THE PTO STOPS PULLING WHEN I GET A LOAD ON IT BUT THE WHEELS KEEP ON PULLING.AM I CORRECT IN ASSUMEING THAT THIS TRACTOR HAS A DUAL CLUTCH ON IT?
wayne from mi
05-25-2004 18:34:10
 Re: CLUTCH ON MF35 in reply to RICK ADAMS, 05-25-2004 10:59:56
you are correct... sounds like a severly out of adjustment pto clutch or a bad one... wayne
txblu
05-26-2004 09:59:50
 Re: Re: CLUTCH ON MF35 in reply to wayne from mi, 05-25-2004 18:34:10
Ok Wayne you may be the man I'm looking for. Just bought a MF 35 with dual clutch. The PTO is at the bottom of the pedal travel and the ground speed is at the top. On my Ford with Live PTO, they are pretty close together.
Can this adjustment be corrected on the tractor, or does it have to be split and the clutches removed and taken to the shop and put on an alignment jig?
Thanks,
Mark
wayne in mi
05-26-2004 16:27:38
 Re: Re: Re: CLUTCH ON MF35 in reply to txblu, 05-26-2004 09:59:50
contact big deans web site, he has an adjustment procedure either on the site or its available on a disc he sells for a very resonable price i can tell you that it may be able to be adjusted so it won't slip as long as it hasn't been sliped for too long... i wish i was good enough to tell you how to do it but i can't, ive done it on my 235 though and its not bad to do, mine was the oposite though didnt want to disengage!!
txblu
05-27-2004 06:03:39
 Re: Re: Re: Re: CLUTCH ON MF35 in reply to wayne in mi, 05-26-2004 16:27:38
Will do and thanks. I'll give him a couple of days to catch up. Seems he just got home from the hospital and the mail is stacked up.
Mark
