m.f.50 deisel wont start
hank in texas
05-23-2004 20:40:54
i started my 50 deisel today and loaded up the sprayer and filled it. decided to grab a sandwich so i killed it. 45 minutes lter it just clicked. wouldnt trn over. trans in neutral,battery puttin out 12 volts on meter.coil to starter puttin out 12 volts. when i turn the switch the amp guage goes to the minus side. also tried jumping the battery with no luck. need help. any suggestions. thanks hank
Dan
05-25-2004 15:57:59
 Re: m.f.50 deisel wont start in reply to hank in texas, 05-23-2004 20:40:54
It's most likely your solinoid. Disconect your
battery cables .(from the battery)Now disconect
the posative cable from the solinoid,followed by
the small wire marked 's'on the front of the solinoid. Next you can disconnect the ground strap that goes from the front of solinoid to the front of the starter.You will have to take both ends of it off to get the solinoid open.Remove the two screws in the end of the solinoid.Inside you will find a copper disk with a spring on the end of it. Clean it with emerycloth or a fine wire brush. Before you put it back togather,clean all of the other conections in the cover. It's not a bad idea to put a small dab of grease on the shaft end of the contact disk.
Dave
05-24-2004 19:41:16
If all else fails.Try to take starter loose. Sometimes they will get stuck. When you get it loose it should set itself free. I do not beleive that you will have to take it off. Please let me know if this works. Thanks,Dave
MF
05-24-2004 05:25:52
Check and CLEAN all of your battery/cable connections. Charge the battery fully. Try again. Your starter solenoid, the part that the battery cable goes to, would be the next thing to check. Did you leave anything on that drains the battery? An outside shot: the starter could be getting bad.
