Permatran III transmission oil
Keith Zammit
05-23-2004 05:34:02
Is there a substitute out there for the MF Permatran III transmission fluid. My dealer lives over 100 miles away and I don't want to go there.-Thanks Keith
tractor dan
05-24-2004 08:54:08
 Re: Permatran III transmission oil in reply to Keith Zammit, 05-23-2004 05:34:02
See the discussions on this board re: substitute oils. The most important thing is the GL rating on the fluid. Make sure the rating on the fluid you buy is the same as what is required. The additives in GL4 and GL5 can damage older trannys and pumps.
mark
05-23-2004 11:01:27
Check the specs on the generic universal tractor fluid found at TSC or Farm and Fleet,or NAPA,you may find it meets MF's specs for their oil.
Yes,
05-23-2004 06:45:08
there are many aftermarket hydraulic oil suppliers, even Wal-Mart, NAPA, TSC, etc. If you are working your tractor hard or really depend on it for your business, you might just want to make that trip and "Load Up". I have used the "other" oils and haven't had significant problems but others have had different experiences.
Abdul Azeez
09-12-2006 01:18:25
 Re: Re: Permatran III transmission oil in reply to Yes,, 05-23-2004 06:45:08
Could you please provide product data sheet of MF Permatran III - M1135
txblu
05-25-2004 09:35:05
I buy generic oils from reputable dealers (including Wallyworld), keep equipment clean with filters changed regularly, and keep all tractors shedded. I buy the red NXXX-2 rated grease by the case and am not afraid to use it often and lots of it.
I use oils with my particular spec listed on the container including mineral oil (GL-1 90W).
In 40 years, have never had a piece of equipment fail due to an oil related condition. Believe it or not, I have yet to wearout an engine or drive line. Clean oil can't be beat.
Think about this: How much does 5 gallons of oil cost vs just one transmission gear, or one engine piston? No comparison.
txblu
