clutch problem TO 20
Dick Wilson
05-22-2004 09:53:49
The clutch was working when I parked the trator. Several weeks later, not working. Tried pedal adjustment, no help. I took off that little 2 inch square casting on the top of the clutch housing (under the battery). The under side was rusty and the small arm attached to the casting was not free on the shaft that it swings on. There is bracket with two holes in it and a small counter weight on the arm, BUT NOTHING WAS HOOKED TO IT. Is there something that is supposed to be hooked here that is necessary for the clutch to work?>
