MF 20-C transmission clang
Wayne
05-22-2004 06:02:11
I just bought MF 20-C about a month ago. After about an hour, the transmission housing starts clanging. I think maybe I should change the transmission oil. Do I use SAE 90? How much? Should I be looking at something else as the problem?
marlowe
05-22-2004 08:38:15
 Re: MF 20-C transmission clang in reply to Wayne, 05-22-2004 06:02:11
also you [[[DO NOT]]] use 90wt in the trans. not sure if its M1103 or permatram but for sure NOT 90wt.
clang
05-22-2004 06:32:19
If both levers for the 3-point hitch are all the way up, you will often have a knocking sound in the case. There should be a decal by one of the levers saying something like "constant pumping". The constant pumping position is only for use with certain auxiliary hydraulic equipment.
Wayne
05-22-2004 06:39:53
 Re: Re: MF 20-C transmission clang in reply to clang, 05-22-2004 06:32:19
Thanks! Who knew it could be so simple. You are the man!
