a pluse in the pedle
patrickvol
05-20-2004 19:25:28
i am looking for my first tractor, and i have found a MF-35 with a diesel motor. everthing seemed to work fine but there is a pulsating in the cluch pedal. its only felt when the pedal is pushed in and on in the pedal, and not the hole tractor. other than that it seems to be a good tractor. any ideas of what would be causeing it to do this?
thanks
patrick
sibby(Aus)
05-22-2004 07:44:02
 Re: a pluse in the pedle in reply to patrickvol, 05-20-2004 19:25:28
Patrick, sounds like the three adjusting screws on the clutch pressure plate levers are incorrectly adjusted or your flywheel or pressure plate need machining due to high spots. cheers sibby.
