MF 135 engine
Glenn
05-19-2004 23:01:50
I've got a 1961 Massey Ferguson 135 with a three cylinder gas engine. How do I tell if the engine is a Perkins versus a Continental and where do I look for the engine serial number. Thanks, guys!
Carla
05-21-2004 17:24:44
 Re: MF 135 engine in reply to Glenn, 05-19-2004 23:01:50
We just purchased an old Massey Ferguson 135, diesel engine.
The belt keeps slipping off between the fan and the alternator. The alternator is mounted funny,at an angle, or slight tilt maybe and pulls the belt crooked when the belt is put back on.
I'm sure this is why the belt jumps off, but how do we fix it??
Thanks
E Glenn
05-22-2004 09:03:45
 Re: Re: MF 135 engine in reply to Carla, 05-21-2004 17:24:44
make a new alternator bracket. it's easy to do.
sibby(Aus)
05-22-2004 07:37:34
Carla, sounds like the mounting bracket is bent or the mounting bolts worn or too small for the holes in the bracket maybe. did it have an alternator fitted from new?, or did someone maybe replace a generator with another bracket which is misaligned.? regards sibby.
Peter
05-21-2004 07:38:35
on the alternator side, behind the alternator, up under the side sheet metal, it will say "AG-152"
they put a different cylinder head on the Perkins "AD-152" plus a carb and made your tractor
great tractor and please take good care of it
Chuck Bergstrom
05-20-2004 19:43:26
If you have a 135 MF it is not a l961. 135 models
started out with a 4 cyl continental gas or a 3
cyl diesel. In l969 MF switched to a 3 cyl Perkins
gas. If you have a 3 cyl gas it is a l969 or newer.
glenn
05-22-2004 00:24:40
 Re: Re: MF 135 engine in reply to Chuck Bergstrom, 05-20-2004 19:43:26
Chuck -- Thanks for the info. I'm guessing the previous owner said it was a '71 ( not '61 ). Also think I messed up trying to replace the oil filter cartridge by telling the guy at the local MF dealer that it was a Continental. When I started the tractor with the new filter cartridge, the oil pressure gauge maxed out. I shut off the engine and haven't tried to re-start it until I could get some better information about the engine in this model. Guess I'll go back to the dealer and try again! Thanks for your help. Glenn
Kenneth
05-20-2004 18:42:04
If ya got a 3 pot petro engine in ya 135, ya can be sure its from Perkins. Continentals were all 4 pots.
Wilho
05-20-2004 13:43:34
I could be totally wrong but my understanding was perkins is deisel and cont, gas ?????
Don-Wi
05-23-2004 14:54:15
 Re: Re: MF 135 engine in reply to Wilho, 05-20-2004 13:43:34
Up until '69 you would be right, then perkins gas engines were used instead of the cont.
Donovan from Wisconsin
Ben UK
05-19-2004 23:46:15
On the perkins it is on the left hand side
