TO-35 Massey Made in England
Mark in Mi
05-19-2004 11:27:05
I have in my possion this tractor. Don't know much about it. Can anyone tell me it's approx. value. Serial #SDM 132070. It runs and all gears work along with PTO and 3 point. Tires have alot of life in them but are weathered. Clutch works well. Sheet metal for the most part is straight except for under the grill. All fluids are up and good and doesn't smoke after warm up.
Thanks in advance.
Mark
Paul in AZ
05-20-2004 12:16:42
 Re: TO-35 Massey Made in England in reply to Mark in Mi, 05-19-2004 11:27:05
Mark, based on the SN, I believe you have a Ferguson FE-35, built in the UK in 1959. The "S" in the SN prefix means it has a standard chassis. The "D" means it has a Standard Diesel engine, and the "M" indicates it has a dual clutch system. Many of them were imported into Canada and found there way south to the States. The value varies anywhere from $2000 - $3800, depending upon the over-all condition.
C. T. in Oklahoma
05-20-2004 13:42:49
 Re: Re: TO-35 Massey Made in England in reply to Paul in AZ, 05-20-2004 12:16:42
Paul, What is your source? I can't locate his serial number on the sites I use. I am always watching for new sources. Thanks, C. T.
Paul in AZ
05-21-2004 13:06:43
 Re: Re: Re: TO-35 Massey Made in England in reply to C. T. in Oklahoma, 05-20-2004 13:42:49
I have several old SN lists produced by MF over the years. I will e-mail you the one with the FE-35 numbers.
Paul Nelson
Thomas
05-20-2004 10:40:41
TO tractors were made in Detroit, hence Tractor Overseas. Tractor England (TE) tractors were made in Coventry.
