MF30B loud engine knock
Norbert
05-17-2004 14:24:05
I recently changed the fuel filter after losing power. After the filter change I developed a loud knock at the front of the engine. Could this be a rod, injector problem, or valve problem?
MF Kid
05-17-2004 17:08:42
 Re: MF30B loud engine knock in reply to Norbert, 05-17-2004 14:24:05
Does it do it when it is hot? Sounds like a piston collapsed from overheating. Although rare, it could be "fuel knock" from a injector or something. If the engine was running lean because of a lack of fuel under a load, it possibly burned a piston. Does it have a lot of blowby from the breather? If it does, consider a overhaul. Most generally, if the filter is clogged, it will just be short on power or not even run. In which case the fuel tank should be looked at for crap in it. Might want to check valve adjustment also.
