ford I9-337 loader on Massey 135??
Les Lane
05-16-2004 15:30:22
Will a Ford I9-337 front loader bolt on to a Massey Ferguson 135 tractor or are modifications to the loader necessary? If so, what needs to be done to bolt it on?
Many thanks,
Les Lane
Les Lane
06-25-2004 08:02:06
 Re: ford I9-337 loader on Massey 135?? in reply to Les Lane, 05-16-2004 15:30:22
Well, the loader is on and it works great! It is not too hard of an installation. The Ford loader is about 3 inches longer than a MF loader so the front mounting plate needs to be stood off by about 3 inches. The rear mounts are a bolt on. The bucket hydraulic controls need to be moved up 6 inches to clear the sheet metal. The drive shaft for the hydrualic pump has to be lengthened by about 7 inches. After all that, it bolts up and works fine. Just need to find a power steering conversion now.
Les Lane
lonestarjeff
05-19-2004 16:27:22
Not a direct bolt-on, but I fit a Ford 701 on my 165.
I used the front bracket from the loader & fabricated a belly bracket for the mid-mounts since the 165 is too long for the loader frame
rear mounts.
Your 135 is pretty close to the same length as the Ford 600-900 series(which your loader was designed for).
Hope this helps,
Jeff
Les Lane
05-19-2004 17:48:56
 Re: Re: ford I9-337 loader on Massey 135?? in reply to lonestarjeff, 05-19-2004 16:27:22
Hi Jeff!
Thanks for the information. I will know in a day or so if it fits directly on or not. The basic measurements say it will but my Fergie has a solid pivot pin for the front axle and I am in the process of replacing it with one with a 1" hole in it and rebushing the front end in the process. Should be ready to fit it up by the weekend though.
Thanks again.
Les Lane
