MF 204 workbull W/ Reverse-o-matic (Parts?)
Wayne
05-14-2004 13:38:38
Hello
Question: Are parts still available for the reverse-o-matic transmission? And how can I tell what year my tractor is? Is the date stamped somewhere on the frame? The S/N is JGA 344064 Maybe someone out there can tell from this number.
Thank you
Wayne
MF Kid
05-14-2004 17:57:53
 Re: MF 204 workbull W/ Reverse-o-matic (Parts?) in reply to Wayne, 05-14-2004 13:38:38
The parts still should be available at your local Massey dealer including torque converter and clutch pack parts.
Wayne
05-14-2004 18:35:28
 Re: Re: MF 204 workbull W/ Reverse-o-matic (Parts in reply to MF Kid, 05-14-2004 17:57:53
Thank you MF Kid, for the reply...I can sleep at night now. I was a little worried cause I wasn't seeing after market parts on the internet.,Thanks Again! Wayne
MF Kid
05-15-2004 08:10:28
 Re: Re: Re: MF 204 workbull W/ Reverse-o-matic (P in reply to Wayne, 05-14-2004 18:35:28
This is a very common industrial tractor. They are pretty simple to repair. My advise to you if you are having to repair the instant reverse, is to replace the torque converter and front pump as they usually wear out and the pump leaks oil externally. Also replace the clutch packs. Make sure you watch how you install the steel plates in the clutch packs. They are concaved and it is hard to see if you are not looking closely. They all have to be the same direction! Check the clearence on the shafts and bearings. You should do fine. I bet Big Dean has some info on this tractor.
