MF35 valve adjustment
garvas
05-13-2004 04:27:57
I need to adjust the valves on my gas 35. I woul prefer to do this with the motor not running. Any thoughts on this... I think the book says .13 cold - but will need to look it up. What is a realistic setting cold? Thanks gang..... .
bstrucker
05-13-2004 10:35:16
 Re: MF35 valve adjustment in reply to garvas, 05-13-2004 04:27:57
Any valve adjustment on a tractor needs to be done with the engine off.13 cold sounds about right.
dirthog
05-15-2004 04:17:39
 Re: Re: MF35 valve adjustment in reply to bstrucker, 05-13-2004 10:35:16
Actually the owners manual for a MF35 tells you to adjust the valves with the engine hot and running, so I'm sure it can be done. Although I don't take that route.
bstrucker
05-15-2004 05:24:10
 Re: Re: Re: MF35 valve adjustment in reply to dirthog, 05-15-2004 04:17:39
Somebody correct me if I'm wrong,but a massey 35 has solid lifters,so I don't see how you could set them running.If it says hot,thenyou warm the engine before adjusting,but usually the lash is only a couple .000 difference between hot and cold.
dirthog
05-15-2004 14:32:49
 Re: Re: Re: Re: MF35 valve adjustment in reply to bstrucker, 05-15-2004 05:24:10
Actually the manual I was looking at was for a MF65 with the continental 4 cyl. I just checked and the manual for that says to check with engine running.
1. run engine till opearating temp. achived
2. open hood, remove gas tank and cylinder cover
3. attach temp. auxiliary gas tank and opearate engine at a slow idle
4. set the four intake valves at .016 and the exhaust valves at .018 inches
it also goes on to say you can also adjust them with the engine off.
