Starting problem on MF 202
K L
05-13-2004 03:16:07
Having a problem getting the tractor to start and not sure where to look.
Briefly, have replaced all the basics, plugs, points condensor and distributor cap. Have done an inspection on all wiring(not just spark plug wires but the wiring for the electrical system as well) and fixed one bad connection along the way. Everything electrical on the tractor works except that there is no spark at the sparkplugs. I have gone so far as to pull them one by one to check to see if there was a spark while the starter was cranking and found nothing.
Mechanically everything seems to be in working order. Just seems to be coming up short electrically.
Would appreciate any ideas.
Thanks
Jack
05-13-2004 15:32:35
 Re: Starting problem on MF 202 in reply to K L, 05-13-2004 03:16:07
Might try another condensor. New parts sometimes aren`t perfect. Good Luck
jake
05-13-2004 07:04:44
check that you have 12volts(or near 12) @ coil input while cranking.
