Diesel fuel in oil
Kevin (WI)
05-11-2004 14:28:40
I have a Massey 1100 with diesel fuel in the pan. New lift pump, Injection pump changed. Any other place it can be coming from? Engine is tired. Hoping someone else has some info Thanks
sibby(Aus)
05-12-2004 04:36:06
 Re: Diesel fuel in oil in reply to Kevin (WI), 05-11-2004 14:28:40
Kevin, You say you have a new lift pump fitted, should be o.k. Was the injector pump reconditioned.? Could be a faulty seal or damaged seal or damaged or worn seal surface in your injector pump, might be a good idea to talk to person who reconned the pump. regards, sibby.
Ray,IN
05-11-2004 20:52:34
Most common cause is a hole in the diaphram of the primary fuel pump.
Kevin (WI)
05-12-2004 04:58:07
 Re: Re: Diesel fuel in oil in reply to Ray,IN, 05-11-2004 20:52:34
I was reading past history posts. Don-WI 1-2-04 posted Check banjo bolt in the return line It has a very small hole in it. The small hole is to allow back pressure in fuel system???? Any comments. Lift pump brand new. Pump switched from tractor that did not have fuel in pan. Rebuilt year ago. Don also commented, if the hole is blocked you can repair leaks from injection pump front seal and it will still leak fuel into crankcase. Thanks again I am going to look into this
Chuck Bergstrom
05-12-2004 08:52:57
 Re: Re: Re: Diesel fuel in oil in reply to Kevin (WI), 05-12-2004 04:58:07
I would still suspect the fuel lift pump. This
was almost always the culprit. Next the injection
pump-was it checked over or just removed from
another tractor?
Kevin (WI)
05-12-2004 09:24:45
 Re: Re: Re: Re: Diesel fuel in oil in reply to Chuck Bergstrom, 05-12-2004 08:52:57
Brand new lift pump. Injection pump came off of running tractor that was not getting fuel in engine. Was rebuilt 1 year ago If the injection pump was not leaking on other tractor why would it leak on this tractor right away? Thanks
